Are there any cables for the Moonraker Titan MKII? I think it has a RJ45 jack at the back
Doesn’t look like this radio has any accessory ports so the interface would have to be via the mic and speaker connections
The manual doesn’t have the pinout for the mic, but I found this one on the internet:
If correct, then the Digirig audio cable will look like this:
MIC pin 1 (PTT) –> 3.5mm TRRS ring 2 (RIG_PTT)
MIC pin 2 (GND) –> 3.5mm TRRS sleeve (GND)
MIC pin 3 (MIC) –> 3.5mm TRRS ring 1 (RIG_AFIN)
SP tip –> 3.5mm TRRS tip (RIG_AFOUT)
The cable will have a speaker tail similar to this one:
