Proposed wiring from the MXM600 26-pin accessory connector. Pin numbers are from a user’s reading of Motorola’s documentation, not verified here:
pin14 (RX_AUDIO) → 3.5mm TRRS tip (RIG_AFOUT)
pin11 (TX_AUDIO) → 3.5mm TRRS ring1 (RIG_AFIN)
pin17 (EXTERNAL_PTT) → 3.5mm TRRS ring2 (RIG_PTT)
pin12 (GND_ANA) → 3.5mm TRRS sleeve (GND)
pin8 (GND_MAIN) → 3.5mm TRRS sleeve (GND)
Digirig pulls PTT to ground to transmit, so EXTERNAL_PTT needs to be the active-low type. The radio doesn’t support serial CAT, so the Digirig Lite covers it (audio and PTT via GPIO3 or VOX):
No store cable. If you build one, please post your results here.
