My self-made Digirig Mobile is ready. From PCB board printing to original parts procurement to welding, as well as the design and production of the 3D shell, I only used my spare time to do this, which took about three weeks. Now it works fine. The radio equipment I use is IC-2730A, and I will consider trying CAT control later. I will continue to update the post after my serial control line is ready. Thanks for K0TX.
Congrats on your success!
Your project confirms that Digirig is truly an open source project allowing community to recreate and customize the design.
Wow!
This is completely news for me that you could build your own hardware module!
Could you please guide on what references were used?
Thank you for the prompt response!
Do you still use it? Are you satisfied with it?
