New Chirp and the FT5DR
Long time fan of Digirig. I have multiple cables.
I am trying to get my FT5DR to connect to my laptop using New Chirp, so I can share memory channel settings with other radios. I may have forgotten previous instructions. I have the cable, and connect the 90 end to the radio. I have tried plugging the straight end into the Serial port as well as the Audio port on my digirig mobile, with no success.
I know the digirig is working, as I get the same USB and Digirig to connect to Baofeng radios on other cables with the same software.
Any help will be appreciated.
Bob,
The stock FT-5DR cable is wired for audio and PTT. It doesn’t offer serial connectivity.
In case of Baofeng there are two cables in the kit - one for data modes (audio + PTT) and another for serial programming. At this time there is no off-the-shelf programming cable for Yaesu HTs.
Can you remind us which colour is the data set and which colour is the serial programming version?
In case of Baofeng cable set, the one with green molding is for the serial programming.
