I’m having a similar problem to the fellas above. I tried to get digirig to work with svxlink following a few howtos on the web and could usually get Tx to work (Pi → other rigs on the freq) but no Rx (other rigs to the Pi). At one point I could get svxlink to respond to DTMF, but no actual voice to the Parrot server (for example).
I redid the whole Pi using SvxlinkBuilder and re-configuring the resulting svxlink to use serial/RTS for PTT. But now it transmits OK (Periodic station IDs are heard) but the Pi does not receive well … not even DTMF at present. When I send DTMF squelch opens and closes for a second, followed by PTT transmitting for a couple of seconds, but the sound does not  come through.
Help anyone???
SVXLINK.CONF
Configuration file for the SvxLink server
Currently set for SimplexLogic
[GLOBAL]
MODULE_PATH=/usr/lib/aarch64-linux-gnu/svxlink
LOGICS=SimplexLogic
#LOGICS=RepeaterLogic,ReflectorLogic
CFG_DIR=svxlink.d
TIMESTAMP_FORMAT=“%c”
TIME_FORMAT=“24”
CARD_SAMPLE_RATE=48000
CARD_CHANNELS=2
LOCATION_INFO=LocationInfo
#LINKS=LinkToReflector
[SimplexLogic]
TYPE=Simplex
RX=Rx1
TX=Tx1
MODULES=ModuleHelp,ModuleParrot,ModuleEchoLink
CALLSIGN=EL-KE2CST
TIME_FORMAT=“24”
CW_AMP=-10
CW_PITCH=650
CW_CPM=95
SHORT_IDENT_INTERVAL=15
LONG_IDENT_INTERVAL=60
EVENT_HANDLER=/usr/share/svxlink/events.tcl
DEFAULT_LANG=en_GB
RGR_SOUND_DELAY=0
RGR_SOUND_ALWAYS=1
#TX_CTCSS=ALWAYS
MACROS=Macros
FX_GAIN_NORMAL=-1
FX_GAIN_LOW=-12
#QSO_RECORDER=8:QsoRecorder
#ACTIVATE_MODULE_ON_LONG_CMD=4:EchoLink
#ONLINE_CMD=998877
#ONLINE=1
MUTE_RX_ON_TX=1
MUTE_TX_ON_RX=1
#STATE_PTY=/var/run/svxlink/state
#DTMF_CTRL_PTY=/dev/shm/simplex_dtmf_ctrl
#CTCSS_TO_TG=77.0:999,123.0:9990,146.2:9992
#CTCSS_TO_TG_DELAY=1000
[RepeaterLogic]
TYPE=Repeater
RX=Rx1
TX=Tx1
CALLSIGN=EL-KE2CST
TIME_FORMAT=“24”
CW_AMP=-10
CW_PITCH=650
CW_CPM=95
#IDENT_ONLY_AFTER_TX=4
#EXEC_CMD_ON_SQL_CLOSE=500
DEFAULT_LANG=en_GB
RGR_SOUND_DELAY=0
#REPORT_CTCSS=118.8
#TX_CTCSS=SQL_OPEN
MACROS=Macros
#SEL5_MACRO_RANGE=03400,03499
FX_GAIN_NORMAL=0
FX_GAIN_LOW=-12
#NO_REPEAT=1
IDLE_TIMEOUT=15
#OPEN_ON_1750=600
OPEN_ON_CTCSS=100
#OPEN_ON_DTMF=*
#OPEN_ON_SQL=10
#OPEN_ON_SEL5=01234
#OPEN_SQL_FLANK=OPEN
#OPEN_ON_SQL_AFTER_RPT_CLOSE=10
IDLE_SOUND_INTERVAL=4000
#SQL_FLAP_SUP_MIN_TIME=1000
#SQL_FLAP_SUP_MAX_COUNT=10
#IDENT_NAG_TIMEOUT=15
#IDENT_NAG_MIN_TIME=2000
ONLINE_CMD=998877
ONLINE=1
#DTMF_CTRL_PTY=/dev/shm/repeater_dtmf_ctrl
#CTCSS_TO_TG_DELAY=0
[ReflectorLogic]
TYPE=Reflector
#HOSTS=45.76.244.170
HOSTS=svxportal-uk.ddns.net
FMNET=svxportal-uk.ddns.net
#API=http://svxportal-uk.ddns.net:81
HOST_PORT=5300
CALLSIGN=EL-KE2CST
AUTH_KEY=“GET YOUR OWN KEY”
DEFAULT_LANG=en_GB
JITTER_BUFFER_DELAY=0
DEFAULT_TG=0
MONITOR_TGS=235,2350
TG_SELECT_TIMEOUT=60
ANNOUNCE_REMOTE_MIN_INTERVAL=300
NODE_INFO_FILE=/etc/svxlink/node_info.json
to be added added on connection to svxportal-uk
MUTE_FIRST_TX_LOC=0
MUTE_FIRST_TX_REM=0
TMP_MONITOR_TIMEOUT=0
[LinkToReflector]
CONNECT_LOGICS=SimplexLogic:9:UK,ReflectorLogic
DEFAULT_ACTIVE=1
OPTIONS=DEFAULT_CONNECT,NO_DISCONNECT
TIMEOUT=0
[Macros]
1=::91235#
9=::910#
2=::9123526#
8=::9#811#
7=::8#91#
[QsoRecorder]
REC_DIR=/var/spool/svxlink/qso_recorder
#MIN_TIME=1000
MAX_TIME=3600
SOFT_TIME=300
MAX_DIRSIZE=1024
#DEFAULT_ACTIVE=1
#TIMEOUT=300
#QSO_TIMEOUT=300
#ENCODER_CMD=/usr/bin/oggenc -Q "%f" && rm "%f"
[Voter]
TYPE=Voter
RECEIVERS=Rx1,Rx2
VOTING_DELAY=200
BUFFER_LENGTH=0
#REVOTE_INTERVAL=1000
#HYSTERESIS=50
#SQL_CLOSE_REVOTE_DELAY=500
#RX_SWITCH_DELAY=500
#COMMAND_PTY=/dev/shm/voter_ctrl
#VERBOSE=1
[MultiTx]
TYPE=Multi
TRANSMITTERS=Tx1,Tx2
[TxStream]
TYPE=Local
AUDIO_DEV=alsa:hw:Loopback,0,2
AUDIO_CHANNEL=0
PTT_TYPE=SerialPin
TIMEOUT=7200
TX_DELAY=0
PREEMPHASIS=0
[NetRx]
TYPE=Net
HOST=remote.rx.host
TCP_PORT=5210
#LOG_DISCONNECTS_ONCE=0
AUTH_KEY=“Change this key now!”
CODEC=OPUS
#OPUS_ENC_FRAME_SIZE=20
#OPUS_ENC_COMPLEXITY=10
#OPUS_ENC_BITRATE=20000
#OPUS_ENC_VBR=1
[NetTx]
TYPE=Net
#TX_ID=A
HOST=remote.tx.host
TCP_PORT=5210
CODEC=OPUS
#OPUS_ENC_VBR=1
[Rx1]
#RX_ID=K
TYPE=Local
AUDIO_DEV=alsa:plughw:0
AUDIO_CHANNEL=0
SQL_DET=VOX
VOX_FILTER_DEPTH=190
VOX_THRESH=1000
SQL_START_DELAY=1
SQL_DELAY=10
SQL_HANGTIME=10
#HID_DEVICE=/dev/hidraw0
#HID_SQL_PIN=VOL_DN
#DTMF_SERIAL=/dev/ttyS0
#SQL_GPIOD_CHIP=gpiochip0
#SQL_GPIOD_LINE=!23
#SQL_GPIOD_BIAS=PULLUP
#SIGLEV_SLOPE=1
#SIGLEV_OFFSET=0
#SQL_SIGLEV_OPEN_THRESH=30
#SQL_SIGLEV_CLOSE_THRESH=10
DEEMPHASIS=0
SQL_TAIL_ELIM=270
PEAK_METER=0
DTMF_DEC_TYPE=INTERNAL
DTMF_MUTING=1
DTMF_HANGTIME=100
DTMF_MAX_FWD_TWIST=8
DTMF_MAX_REV_TWIST=6
FQ=145212500
MODULATION=NBFM
DTMF_CTRL_PTY=/tmp/dtmf_svx
[Tx1]
TYPE=Local
#TX_ID=K
AUDIO_CHANNEL=0
PTT_TYPE=SerialPin
PTT_PORT=/dev/ttyUSB0
PTT_PIN=RTS
#HID_PTT_PIN=GPIO3
#PTT_GPIOD_CHIP=gpiochip0
#PTT_GPIOD_LINE=!24
#PTT_GPIOD_BIAS=PULLUP
PTT_HANGTIME=10
TIMEOUT=0
TX_DELAY=0
PREEMPHASIS=0
#DTMF_TONE_LENGTH=100
#DTMF_TONE_SPACING=50
#DTMF_DIGIT_PWR=-18
