I just want to register my complaint that there seem to be no current VHF/UHF mobile rigs on the market with CAT control of frequency and settings (via serial or USB) and with 9600 audio (passing wideband, un-filtered baseband audio).
The only rigs I can find with these features are legacy rigs. Or have to get a recent model very expensive shack-in-a-box rig that has HF as well as the VHF/UHF, just to get these features.
I don’t need a built-in TNC, rather I want to be able to use a software modem/TNC without mic audio processing and be able to tell the radio from a computer what settings are needed for a particular mode with a simple protocol like CAT.
And I don’t want to have to pay $1500 for a UHF/VHF mobile rig with these features that used to be pretty basic.
With all the requirements applied, indeed there are no matches that I know of:
dual band VHF/UHF
currently in production
9600 baud flat audio
CAT control supported
under $1000 (assuming based on your non-acceptance of $1500)
If you loosen up one of the categories, I’d go with TM-D710 for not in production radios, AnyTone AT-D578 for non 9600 baud or with Yaesu FT-991A higher priced one. The last one you may find under $1000 used.
EDIT: Doh, Yaesu discontinued production of the FT-991A earlier in the year. Don’t tempt me, I have enough projects…
Kenwood TM-D750A is the closest current match: in production, with a 9600 bps data port and USB audio per the manual, and it accepts PC commands over USB. Kenwood doesn’t publish the command set in the user manual, but frequency and mode control already work in d750ctrl. It runs around $1200.
AnyTone AT-D578 needs a caveat: CAT on it is the hand mic’s serial link. PTT works that way, and the VFO frequency can be keyed in from the mic, so frequency control means emulating key presses. The d578uv project documents the key codes, but I haven’t seen a report of frequency control done that way.
