Problem solved…OE…after working with a patient tech at digirig, we ran some tests on the cable to trigger the tx. After unplugging and replugging the cable connections, the mid section was not fully seated. Subsequently, no setting in the world would have worked. A good YouTube tutorial on troubleshooting provides the quick and easy tests. So, my bad. Things are working like they’re supposed to now…
select RA-Board in VaraFM
the digirig lite uses GPIO (also called cm108,ra-board) for ptt or it’s own onboard VOX circuit
Thank you friend. Problem resolved.
