Just beginning to poke my nose into Winlink (RMS Express) w/both VARA FM (w/Baofeng HT, at least for the moment) and VARA HF (w/both Icom and Elecraft KX3). Assuming I wish to proceed with all of this, would this require (3) separate Digirigs, or can Digirig be reconfigured on the fly (or maybe there’s somehow no reconfig required?) for the necessary CAT control? (I recognize that different cable assemblies are required for interface to these different radios.)
Related question, first priority is with the Baofeng, in combination w/RIGblaster Advantage. Assume it’s viable (no showstoppers) to use this combination of devices to hit a local Winlink node, correct? i.e. The approach I’m considering is not a misapplication?
