Would anyone have the Pin Out guide for ICOM 718 PTT cabel. ( That may be the wrong name of the cable, but it is the cable for the PTT)
I am trying to determine if the cable I have is or is not working right… Please and Thank you
So my guess was right. If I touch R2 and S the rig should attempt to transmit. In which case it is not.
So I may have a faulty cable then.
OK, that is progress! Did you check continuity between R2 and DIN-3?
Not yet. I am currently at my day job. I’ll check that tonight
That was it. Sure enough, the cable sent is not working. No continuity on those pins
Thanks for reporting.
