Powerwerx DB-750B (Anytone AT-778UV)
I’m using the Anytone 778 cable on my Powerwerx DB-750b. I’m following N1SPW’s instructions for Windows 11 Sound Settings. I have the DigiRig Input and DigiRig Output set as “Default Communication Device” but NOT the “Default System Device”. I have another HT monitoring the WinLink Gateway frequency. I’ve turned off Squelch on the DB-750 and adjusted both the system volumes and the rig volume so the VU meter sits at approximately -11dB at idle. For VARA-FM’s “Settings>VARA Setup” I’ve chosen NARROW.
(Note: These are the same settings that work successfully with my Anytone D890.)
When I use VARA-FM’s “Settings>Sound Card>Auto Tune” I hear the sequence of 10 transmissions on my HT, so I know that DigiRig’s PTT activation is working, but every time the Auto-Tune ends with the “NO SIGNAL” warning.
What am I missing?
can you key up the ht and see, on the vara fm ‘scope’, if the needle moves ?
(this would show if the audio from the radio is getting to the digirig and then to the pc)
2 things come to mind;
not enough rx audio (either radio knob or pc slider)
not close enough to gateway you are using auto tune.
you’ve adjusted the sliders so it may come down to distance.
using narrow, the input audio to the radio is very forgiving and you are listening to the output on another radio so i’m not thinking over driven tx audio.
do you hear/see any traffic from the gateway you’re using on the vara fm scope ?
(just an aside, default comm device tells windows to use that souncard for phone calls and similar. i wouldn’t use that. all my setups have the radio soundcard unset to either default)
'monkey
(Starting from the bottom: I reset the Digirig soundcard - both input and output - to “Ready” rather than “Default Communication Device” and the Anytone 890 still connected to a gateway & sent a message. That’s good!)
Back to the top: With the Powerwerx connected to the Digirig & PC and the Anytone set to the same gateway frequency, I tune the Powerwerx so the VARA VU meter is at -12dB +/-. Then I press PTT on the Anytone and the VARA VU meter drops all the way to left (i.e. 9 o’clock). I don’t know what this means.
I also don’t understand how distance could be a factor, as the Anytone and the Powerwerx are right next to one another and tuned to the same gateway.
There’s no traffic this morning, so I don’t have any data about traffic showing up on the VARA-FM scope.
There’s one variable I haven’t mentioned: antennas. The Anytone HT has a SignalStick. The Powerwerx is connected to a mag-mount Comet 2x4 resting on a ground plane. I can’t see how this would make a difference…
I’m still bewildered!
yes, if the other radio is connecting, then obviously you’re close enough to the gateway.
you’ve got squelch off so unless there is an STE setting on the radio, i’m stymied.
squelch tail elimination can cause the receiver to miss the header of the reply and ignore it.
haven’t seen a radio with it enabled by default since the first gen uv-5r but i’d check if the radio has that setting or similar.
sorry i couldn’t be more help
STE is off… I’ll keep working the problem…
I do appreciate your suggestions!
I’ve heard from a few Powerwerx owners that the rig just isn’t suited for digital modes, especially not VARA. Here’s one comment I received:
"VARA uses a complex mixture of multiple simultaneous QUAM (quadrature amplitude modulation) tones. This type of signal uses both amplitude and phase modulation of each of the multiple audio tones to push more bits-per-second through the radio channel. The faster VARA goes, the more simultaneous tones spread over a wider audio frequency range it uses. This kind of complex audio waveform is far more intolerant of the uneven and limited audio response of the mic/speaker channel of a radio than digi-modes with far simpler waveforms like SSTV, RTTY, PSK-31, MFSK, etc.
For any given radio, it is a luck-of-the-draw whether the combination of internal noise in the mic amp, audio harmonic distortion, audio inter-modulation distortion, distortion created from over-driving the transmitter modulation limiter from too-high an audio level into the mic jack, etc will become the proverbial “straw-that-breaks-the-camels’s back” to prevent the more complex digi-mode waveforms from working. "
Unless I hear from another Powerwerx owner that they’ve successfully worked VARA with their DB-750x, I’m going to assume that this radio will not work. It’s not the fault of Digirig, the Digirig Lite, or the Digirig cable… it’s the radio’s fault.
Thanks for the update. The DB-750X is listed as compatible with the AT-778UV cable, and topic 2711 has a DB-750 running Winlink over packet with it.
The VU meter dropping when the other radio keys up is normal: with squelch off, the idle level is receiver noise, and a carrier quiets it. So receive audio is reaching VARA.
One cheap test before writing the radio off: swap antennas between the Anytone and the Powerwerx. If the Powerwerx connects on the SignalStick, or the Anytone fails on the Comet, it’s the RF path rather than the radio.
I contacted the originator of topic 2711 (aka Gunrunner99). He replied that he never got his Powerwerx DB-750 to work…
Robert
Thanks for checking with him. That removes the only DB-750 report I had, so this corrects what I wrote above - the cable matches the radio’s pinout, but there’s no confirmed VARA FM result with it yet. Have you had a chance to try the antenna swap?
I’ve tried several antenna combinations, but none work. I’m going to try to sell the radio at a swap meet and buy a different one that’s known to work.
