PTT issue with Digirig Mobile and Baofeng UV17
I have a new Digirig Mobile with factory cables for the Baofeng radio. I’m using W0AD on an Amazone Fire Tablet. I set up the Packet session as described in the posts I have read here concerning PTT. When I hit the Start for the session, the radio keys and locks up in tx and will not unkey until I unplug the USB cable. Also when the radio keys there is just carrier and no modulation.
I’m using the PTT USB RTS option and I the USB port correctly identified the Digirig. I’ve read the posts and can’t find anything contrary to what I’m doing. Any ideas?
Also radio is a Baofeng UV-17R. i i tried this on my Anytone 868 with the same results
Jim,
You are dealing with RFI. Your radio uses Digirig’s cables as a counterpoise for the antenna lacking a ground plane. This disrupts the USB communication. You can improve the situation with additional choking or by improving grounding and the antenna system.
More on that in “sticky PTT” section of the troubleshooting guide.
