PTT light dim on causing radio to transmit
Brand new Digirig Lite with Alinco DR-130 cables. The radio started toggling between transmit and receive, and the PTT led on the Lite is lit up… dimly. I was not doing this when I first connected in to the PC and radio. and made a few connections earlier today. I have disconnected it from the pc and reconnected with no change. not sure what to look at next.
Disregard. I think I got it figured out and will leave this here for others, just in case. Under SOUND CONTROL PANEL on the Playback tab, under properties for the Digirig Lite, under Levels… there is a microphone slider that was unmuted, evidently this must be muted and somehow I had accidently unmuted it. PTT led is no longer on, except when actually being told to transmit.
