WIth KX2 and Winlink Express I am using the same com port (com9) for both PTT and CAT. Works well. However some programs such as HamRadioDelux can not work with the same com port used for both CAT and PTT.
Is there anyway Ring 1 on the KX2 mic can be used for PTT ?
Alternately, can a virtual com port be set up to “mirror” com9 to a different COM# , so as not to confuse HRD ?
Gordon VE3JSJ
