Radio PTT fine with Winlink and Soundmodem but not FLDigi - using Com4 RTS
Scratching my head. As title states, Digirg 1.6 now with FTM-300 and it works fine with Winlink Vara FM and Winlink Packet using Soundmodem. Both using Com4 RTS to trigger PTT. But can’t get it to work with FLDigi - think that I’ve tried all of the relevant interations and possibilities, but no joy yet. Has anyone found the secret sauce? Thanks! Mike
Try ‘none’ for rig under xsvr and RTS for the PTT under PTT-Generic.
If that doesn’t work, please share the screenshots of the configuration.
@Mike_Forrence that’s frustrating, but you are close to success. K0TX is suggesting that you use flrig.
With Digirig 1.9, I use fldigi directly to pull PTT with this configuration:
When “Initialize” is red, you must mouse click the button to initialize for that session.
@Mike_Forrence Please let us know how it works out.
@Constrainted - your version worked like a CHAMP - thanks very much!
And thanks to all who viewed and contributed - hopefully this will also help someone else in the future.
Cheers!
Mike
@Mike_Forrence Thanks for the good news!
Oh WOW… This is what I was experiencing on my FT-857D. I had to use DIG instead of USB or FM to transmit. This solved the problem… I can now transimit using USB and don’t have to switch modes… Thank YOU
