Two questions does this cable support my FTM-7250 dual band Fusion radio? Also does this cable support the TYT 9800, the (FT-8900 knock off)?
Thanks KC8HPS
Yes, both radios you listed should work with RJ12 cables.
When you have a chance, please post the update.
Thanks. As I use both radios with that cable I will give a report. Also in your store regaurding that RJ 12 cable, please update description to reflect that these two radios can use this cable. ![]()
thanks KC8HPS Bryan
