I’m using an RPI4 with KM4ack’s Pi-Build software with a Digirig connected to a Yaesu FTM-400XDR radio. All seems to be working. No CAT control (of course). I set and select the VHF frequency for the local RMS station manually. I’m using VFO B in FM mode (no digital, etc). The FTM-400 PTT works fine. The signal appears to be sent with the Volume bar moving to about 3/4 level. No reply comes back to my call. I can also hear other digital traffic on that frequency so the assumption is the RMS is operating. What other indicators do I need to look for to: 1. ensure my transmission is going out correctly. 2. That the receive side is working properly.
Thanks.
Kevin
WA4KBM
