Running Digirig Lite with Android Tablet and WoAD
Has any one used a Digirig Lite with an Android Tablet and successfully used WoAD. I can not figure out how to make my tablet discover my Digirig.
That should pretty much work out of the box.
When you connected, Digirig should take over the audio input/output on the device.
If that doesn’t happen, try your Digirig Lite with a computer to see if is detected there.
I use a Digirig Mobile and had a similar problem when connecting my Digirig to an Android tablet. An OTG was needed in order for the tablet to recognize the Digirig. I have not tried using WoAD, but my setup is working well with FT8CN.
You need to use a tablet or phone that supports OTG. The USB port will not mount any devices. It will just allow power transfer.
