I am having issues getting ptt to work.I added a usb c hub with no change. I am using an ft 60r with a cable purchased from digirig and android aprs app.
I have changed usb routing and made sure the app has permisions to access the microphone.
Were you able to key up the radio while using Digirig Lite on the full-size computer?
You can also test the cable by simulating the PTT as demonstrated in this video:
I havent tried using a laptop yet.
Hi,
The only other device I have is an Ipad or a macbook.
It seems that send is working and when I click send posistion the digirig and the radio light up. I was able to find my station on aprs.fi but I am not receiving packets
Latest changes:
Downloaded Woad. Not able to send emails when phone has the data turned off.
It still seems that I can send out on APRSDroid but I am not receiving any packets -When I click send position the Digirig and HT both light up in red.
I did connect the Digirig lite to my Windows 10 desktop, downloaded soundmodem and Pinpoint aprs and couldn’t get that to work.
I have verified that out bound works with Android aprs and I see that packets are coming in but they are not showing upon the app. Phone is in airplane mode
have you tried turning up the volume on the radio?
squelch off?
your radio might be missing the header of the response packet,
i know you’re not trying to do ft8 with a vhf/uhf ht but if you run ft8cn, you could observe the waterfall and see changes in the incoming audio.
volume up/down
squelch on/off
etc
