I have used West Mountain Radio Rigblaster for some time but wish something way simpler. I am using Windows 10 on a HP EliteDesk computer. Just want to run FT8. Dipoles in the attic (not good but live in a POA). I understand basic computer settings and WSJT-X settings; I prefer to use JTDX on my big screen TV. I do not wish to spend a bunch of bucks to run FT8 every now and then. A “simple” diagram would greatly help. Looks like the Lite model might be a good choice. BTW I have ferrite on everything! Too much RF in shack!..thanks, Gene
I’d recommend Digirig Mobile instead of Digirig Lite for the CAT-capable base station like IC-706.
You’ll need to pick one in CI-V configuration and use this cable kit:
You’ll also need one of the USB cables.
thanks for the info… this takes care of everything: audio in/out, PTT? I noticed your USB cables have built-in ferrite beads–are these the “good” ones? I think the ferrite beads I purchased from China are junk…
Gene, WA5PWP
Yes, there are good ferrites and shielding.
Sounds good… one last question, With my antennas in the attic (right above me) I tend to get a lot of RF in the shack… have any others had a similar problem. Using the Rigblaster it gave me fits; I was always going back into Windows settings or WSJT settings to redo things. This is no fun.
73, Gene
Of course, go with whatever Denis @K0TX says, but I will offer this:
I have used Digirig with three under-the-roof antennas I use for operating during threat of lightning. I check:
- ARRL RF Exposure Calculator (arrl.org)
- RFI countermeasures listed in Troubleshooting Digital Modes – digirig
good morning;
Thanks for the info, I will purchase sometime but being retired I cannot spare the money.
73, Gene
If you belong to a club, maybe another member can lend you clip-on ferrites to see how many you need. That way, you can order the right number and keep your cost to a minimum.
