I wanted to share my experience with integrating Digrig with Zello to create a bridge between a radio and the famous push-to-talk app.
For context, this is not used for digital coms, but I use it to enable radio communications over internet for my firehouse.
I wrote some Android software to listen to incoming messages on Zello, to drive the radio’s PTT using the digrig serial port.
The source code will be published at some point, and I am looking for people interested in using it, and even participate in the development of the app.
@saiimons any chance you can share this? is it on github or anything? I’m trying to bridge my digirig to zello as well and would love to not have to do a ton of custom scripting to try to get this to work.
I’m trying to use Zello on Android with a DigiRig Lite to transmit audio in a dual-channel setup—voice on the left channel and a tone on the right channel to trigger PTT.
Have you found a reliable way to achieve this? If so, I’d really appreciate it if you could share your approach or any configuration details.
