I am using the Yaesu RJ-12 connector cable for my digirig. I am having trouble configuring Direwolf PTT. It will hear packets, but not digipeat. It worked flawlessly with my Baofeng, but when I changed radios, it will not transmit. I uncommented the ptt line, but I’m not sure it’s assigned to the correct tty device. Anyone have any experience with this?
Did you ever ever get the RJ-12 cable working with the Digirig on the TYT TH9800? I was trying to get it to keyup on VARAFM and EchoLink, and I just cannot get the PTT to trigger? I have confirmed the Com port and I am using the correct jack on the Digirig. A real mystery. 73 WY6Y
Does the correct COM port appear in VARA FM Settings → PTT configuration panel?
Stephen,
Were you able to key up the radio with the simulated PTT method as shown in the video?
