The G90 will not transmitt with FT8
I have a Xiego G 90 I want to use with my DigiRig. I have the 8 pin DIN plugged into the jack on the back for the radio. My WSJT-ALERT works for rig control. The program would not let me connect the UART bridge driver which is on COM7. Instead the program works with COM5. I have see the PNP codecs properly , I am see decodes but unable to transmit. Any help would be appreciate.
Dave NU4N
which digirig are you using?
i’m assuming a digrig mobile with logic levels.
is the g90 in mode: U-D ?
does the radio ‘key up’ but no power output or does the radio not ‘key up’/ptt ?
Yes I am in USB-D mode. I seen a you tube video about using FLRIG for control of WSJT-X. I am going to try that today. Thanks for the reply. Dave NU4N
ok, got the u-d :slight_smile:
i run a g90 and an x5105 with a digirig mobile configured for logic levels.
i use either:
windows pc or laptop running wsjt-x OR samsung S25+ running FT8CN
wsjt-x is configured to control the radio (no middleware such as flrig/omnirig etc)
FT8CN controls the radio on its own as well.
i have PTT method set to CAT/CI-V
(the digirig mobile can also trigger ptt on the g90/x5105 via RTS on the comport)
that’s my troubleshooting checklist
the reason i asked specific questions is that there are bugs in the hamlib ‘updates’ that wsjt-x uses for the xiegu series.
many times, choosing another rig definition will ‘fix’ the problem. if the problem is related to this.
Dave,
Complimenting the PTT troubleshooting tips from @webmonkey here’s a video on the same subject:
The same Digirig COM port number should be used for CAT and PTT by RTS. As pointed out PTT by CAT is also an option.
I will check out the video today. Thanks for the info. I have the DigiRig mobile and would like to use for rig control on FT8 with FLRIG. But can’t find FLRIG in WSJT-X.
Appreciate all you help gentlemen . DAVE NU4N
Sorry to disturb the group. Finally found FLRIG in WSJT-X. I will try using this for control.
73’s Dave
Thanks to all for the help. I gave up on the DigiRig and went back to my SignaLink.
73’s to all Dave NU4N
