Transmitting out of freq
I seem to be having an issue with my G90 and digirig setup transmitting or “splashing” slightly out of frequency when utilizing Fldigi. I assume it is because of overdriven audio, but I honestly have no idea. I have included a picture so yall can see what I see. Also the diamond in the corner of the screen is green and stays that way.
Screenshot 2025-11-17 191452
yes, looks overdriven.
you can set the g90 line input to a lower value to knock that down a bit
I changed line in and out all the way down and I still have the same results.
Am I supposed to be adjusting it on the radio or in the computer settings?
Let’s try a sanity check to make sure it’s not the radio or measurement methodology:
How does it compare to when you whistle into the mic or send CW?
just for reference:
my g90 has ‘AUX Input’ set to 4 (four)
this, along with adjusting the OS volume settings has worked well for me
