Issue Summary:
I am unable to hear Digirig output audio using Tune or Auto Tune functions in Vara FM. The results of my initial troubleshooting leads me to think the remaining culprits could be some finnicky Windows setting preventing audio to/through the Digirig, a faulty usb cable, or a faulty digirig. Are there any other possibilities or troubleshooting tests I should consider?
Detailed information about my setup and troubleshooting attempts is below.
System Components
PC: Lenovo ThinkPad running Windows 11 Pro
Radio: TYT TH-9800
Soundcard Device: Digirig Mobile using Digirig branded cables
Digirig Driver installed as shown in https://www.youtube.com/watch?v=BtSE0TeybfI
Digital Modes Software: Vara FM
System Settings
Windows Sound Settings (Digirig Playback):
Levels: Speakers -10dB, Microphone -23dB
Enhancements: Disable all enhancements checkbox selected
Advanced: Default format set to 16 bit, 48000 Hz
Exclusive Mode: Selected “Allow applications to take exclusive control of this device” and “Give exclusive mode applications priority”
Spatial Sound: Off
Windows Sound Settings (Digirig Recording):
Custom: AGC disabled
Levels: 2.4 dB
Advanced: Default format set to 1 channel, 16 bit, 48000 Hz
Signal Enhancements: Enable audio enhancements disabled
Windows Settings → Privacy and Security → Microphone:
Microphone Access: On
Let apps access your microphone: On
Let desktop apps access your microphone: On (Shows Vara FM Modem is currently in use)
Troubleshooting Tests Already Completed
Test 1: Tune and Auto Tune in Vara FM Listening on separate HT
Observations: Mobile radio connected to digirig engages TX and breaks squelch as observed on secondary HT. No discernible audio is transmitted. Green bars on Windows Sound Settings playback tab light up during Tune and Auto Tune. Auto Tune returns “No Signal” Message in Vara FM
Test 2: Tune and Auto Tune in Vara FM with headphone connected to Digirig
Observations: No discernible audio is transmitted. Green bars on Windows Sound Settings playback tab light up during Tune and Auto Tune. Auto Tune returns “No Signal” Message in Vara FM
Test 3: Tune and Auto Tune in Vara FM with laptop speakers selected in Vara FM Soundcard Device Output
Observations: During Tune a steady tone is heard through laptop speakers. During Auto Tune, ten pulses of digital sound is heard through laptop speakers
Final Notes:
These tests were repeated on both USB ports on the laptop with same results.
