Troubleshooting FT450D with Mac and FL digi
I have successfully removed the trace for the attenuator, and I can get the RX around 30DB if I lower the RF gain some. However, I am unable to get the transmit power not causing ALC on the meter of the 450D. If I slide the output sound in Audio/ Midi setup, i either get no ALC (and no Power out) or ALC (quite high in the scale).
Anyone have any additional ideas? I pulled my hair out.
-Kevin (KK4YEL)
Here are some of the transceiver settings that may be at play based on what I’m finding online:
  • D-TYPE: Ensure this is strictly set to USER-U (Upper Sideband Data).
  • DIG GAIN: Lower this menu parameter down. This acts as an internal hardware attenuator for the data jack audio input. If your incoming Mac audio is too hot, lowering the DIG GAIN value will give you a much wider, more forgiving range on your Mac’s volume slider.
thanks, but this is no digital gain on the US version of the FT 450D, only on original 450. The Data type is USER U
-Kevin (KK4YEL)
What I do (in WS Digital Mode Suite with Tune enabled) is use my arrow keys to tweak my TX power until I see some ALC (usually quite a bit) then lower it gradually a key click at a time rather than trying to drag a slider. The 450D’s ALC is quite sensitive, and slider controls for fine adjustments is a terrible UI decision.
You are talking the power level slider on the right ? I can never get it to drop to any level that is less than 1/2 the ALC meter
Just to verify, you are on a Mac ?
Turn your input audio down in your computer’s sound settings.
Tried also on my iMac. Doesn’t make a difference. I guess my digirig and Mac combo won’t be a solution for my FT450D
I drastically reduced levels of audio and it’s still an issue.
