Hey and good Morning….
I can’t get it to work. I’ve already tried several baud rates and tested many settings, but unfortunately without success so far. Does anyone have a tip for me on what I need to change?
I’m not finding your order by the email address. If you purchased your Digirig Mobile from Amazon then it is in default configuration (logic levels). For the CAT control of TS-480 you’ll need Digirig Mobile in RS-232 configuration. More on the topic here:
Thank you!
After soldering and cutting This Problem is fixed. Test CAT World!
Thank you so much!
Now i have Problems with wsjt-x. ![]()
