I’m trying to figure out how to shut off AGC in Windows 11 Pro. I have JS8CALL installed on a Panasonic Toughpad and the CAT/S level seems low. From what I understand I need to adjust the input from the digirig to adjust this.
In windows 11 pro, on a Panasonic FZ-M1 Toughpad I’m doing the following to attempt to shut off AGC
Start menu, settings, system, sound, scroll down to input, then I attempt to shut off AGC on the digirig input but I don’t see that option.
I’m using this with JS8CALL and the CAT/S is too high. After typing this out I’m thinking this might be a radio setting problem in the FT-817. Is it Mike gain that controls the cat signal?
I’m very new to this and trying to figure it all out.
in win10, you can type mmsys.cpl in the program/run/search box.
this will open the ‘good’ audio control panel.
it does in win10 anyway, i don’t have a win11 pc as of yet
then, click the ‘recording’ tab at the top.
then double click the desire audio device.
then click the ‘custom’ tab.
there should be a ‘check box’ labeled AGC
Slightly related, but I think beneficial for those who are always needing to fiddle with their audio settings - like me
In seeing this post I went looking for a way to create a shortcut for the “‘good’ audio panel” @webmonkey is referencing, which I’m always pulling up. I right-clicked on the desktop and selected “New”, “Shortcut”, and entered; control mmsys.cpl as the “location of the item”.
You can name the shortcut to whatever you wish, and select a different icon if you don’t like the default “mixer” icon.
CAT is the serial remote control communications. changing frequencies, modes, etc
CAT is not the audio input and output, so you can’t ‘adjust’ CAT levels.
if you mean adjusting input/output audio levels on the radio, the MIC gain menu setting won’t change the rear panel connections, only the mic jack.
some radios do have a menu item for input/output levels on the acc/rear jack but it has been a decade since i owned an 817.
