Ubuntu 25.10 - Digirig 891 not attached to /dev/ffyUSBx
Hello,
digirig 891 is not attached to /dev/ttyUSBx
sudo mesg -w shows:
[23399.170625] usb 3-1: new high-speed USB device number 34 using xhci_hcd
[23399.294611] usb 3-1: New USB device found, idVendor=0424, idProduct=2412, bcdDevice= b.b2
[23399.294618] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[23399.335069] hub 3-1:1.0: USB hub found
[23399.335351] hub 3-1:1.0: 2 ports detected
[23399.618612] usb 3-1.1: new full-speed USB device number 35 using xhci_hcd
[23399.693622] usb 3-1.1: device descriptor read/64, error -32
[23399.875621] usb 3-1.1: device descriptor read/64, error -32
[23400.050597] usb 3-1.1: new full-speed USB device number 36 using xhci_hcd
[23400.123626] usb 3-1.1: device descriptor read/64, error -32
[23400.299599] usb 3-1.1: device descriptor read/64, error -32
[23400.401782] usb 3-1-port1: attempt power cycle
[23400.988568] usb 3-1.1: new full-speed USB device number 37 using xhci_hcd
[23400.988645] usb 3-1.1: Device not responding to setup address.
[23401.193624] usb 3-1.1: Device not responding to setup address.
[23401.401553] usb 3-1.1: device not accepting address 37, error -71
[23401.401638] usb 3-1.1: WARN: invalid context state for evaluate context command.
[23401.474556] usb 3-1.1: new full-speed USB device number 38 using xhci_hcd
[23401.474636] usb 3-1.1: Device not responding to setup address.
[23401.681608] usb 3-1.1: Device not responding to setup address.
[23401.889538] usb 3-1.1: device not accepting address 38, error -71
[23401.889639] usb 3-1.1: WARN: invalid context state for evaluate context command.
[23401.889690] usb 3-1-port1: unable to enumerate USB device
[23401.963538] usb 3-1.2: new full-speed USB device number 39 using xhci_hcd
[23402.066866] usb 3-1.2: New USB device found, idVendor=0d8c, idProduct=0012, bcdDevice= 1.00
[23402.066875] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[23402.066878] usb 3-1.2: Product: USB Audio Device
[23402.066881] usb 3-1.2: Manufacturer: C-Media Electronics Inc.
[23402.371057] input: C-Media Electronics Inc. USB Audio Device as /devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb3/3-1/3-1.2/3-1.2:1.3/0003:0D8C:0012.001B/input/input43
[23402.421685] hid-generic 0003:0D8C:0012.001B: input,hidraw4: USB HID v1.00 Device [C-Media Electronics Inc. USB Audio Device] on usb-0000:0d:00.3-1.2/input3
[23408.804525]
Any pointers & help to solve this issue will b appreciated.
Ravi
There is no serial device in DR-891 itself. Do you connect your Digirig to the computer with the FT-891 connected to DR-891’s downstream USB port?
Yes. I connected as shown on the DR 891 page. Tried with 3 different USB A to C cables. USB 1.0 cable did not work. USB 2.0 cable did not work. Cable defective ? With new USB 3.1 (Orange color), Digirig 891 works fine.
Ravi
