I have a G106 and an FT891. I use a Digirig dr-891 with the FT891. I would like to use the dr-891 with the G106. Can I do that? Rather than buying another Digirig, would it just be a matter of changing out the cables?
Yes, you can use the audio side in DR-891 in the same capacity as Digirig Lite:
Additionally, you can use a USB adapter cable from the accessory kit to plug in the serial adapter into DR-891 downlink USB port for CAT control if you decide to use one:
Thanks for the info! I thought it should be possible.
