Using DigiRig Lite with Winlink/SoundModem, FTM-2980
I am using a Yaesu FTM-2980 with a DigiRig Lite & cable to connect to a Win11 computer to run Winlink/SoundModem. The Digi shows up in SoundModem/Devices as “DigiRig (USB Audio Device)” for Output and Input devices. However, for PTT selection it is either “Ports 1-32, CAT, LPT 1-3, EXT, or NONE” as selections. When you try to use Winlink Sessions, the radio will not go into transmit. I think that I have tried all the combinations and still cannot get it to transmit. Suggestions or Fixes ?
Please check out the setup tutorial for Digirig Lite, it covers PTT configuration for soundmodem software here:
