I’ve hit a wall configuring JS8Call to run with my Yaesu FT-891. I’m running windows 11, the digirig mobile, and connecting without the USB connection as suggested by KB8VBR in his video on running FT8 through wsjt-x with the same setup. I have that working fine.
I’m struggling to set up JS8Call without the USB connection to the radio. I’d like to have it run without CAT control, just using RTS for PTT just like on wsjt-x, and then setting the VFO on the FT-891 by hand. When I set the options the way it seems appropriate, it has received some signals, but after a short time I get a “Rig Control Error, would you like to reconfigure” message. So, it seems to be looking for CAT control even though I think I have it set to RTS.
Here are clips of my settings:
The com port is set correctly and I’ve tried both CAT RTS ENABLE and DISABLE on function setting 05-08 on the rig.
I’m guessing I’m missing something obvious, but I can’t find it.
Thanks for any help.
