Vara FM setting for IC 2730 and digirig
Hi, Can anyone who has managed to get the ic2730 using digirig to work with vara fm please tell me the PTT settings that you use - what icom model did you pick from the list as 2730 is not listed.
I do not have your radio, so I cannot answer your question. There are several posts on this forum about your radio:
Latest icom-ic-2730 topics - Digirig Forum
But none that answer my question that I can see!!!
That’s frustrating. I am not sure what to say. The threads consist of users posting what their problem is, what they try, what works, what needs more work. I hope some of them will join this thread. Maybe you can message them.
In the meantime, maybe try COM port RTS instead of CI-V to pull PTT. Do you have input audio working?
There is a troubleshooting guide, Troubleshooting Digital Modes – digirig, which helps you go after one problem at a time.
Here’s the video showing VaraFM settings including PTT:
Additional PTT troubleshooting is covered here:
Many thanks.
Brent Doncliff, RN, MNurs, FCNA(NZ).
