Greetings All,
I just connected the DIGIRIG straight out of the box to my FT-950.
Honest to God it was the easiest interface I have ever connected between computer and radio.
THE FOLLOWING IS THE MILITARY STYLE OF “BY THE NUMBERS” WAY TO CONNECT.
- TAKE DIGIRIG FROM BOX
- CONNECT USB-C - C CABLE END TO DIGIRIG -USB A to COMPUTER
LET RIGIRIG DOWNLOAD UART PROGRAM TO COMPUTER. NOTE: YOU MAY HAVE TO GO TO SILICON LABS TO DOWN THE UART PROGRAM. MY OLD VISTA WOULD NOT DOWNLOAD FROM DIGIRIG SO I WENT AND DOWNLOADED IT FROM SILICON LABS SITE. - GO TO DEVICE MANAGER AND LOOK UNDER PORTS. FIND the COM PORT #NUMBER ASSIGNED TO DIGIRIG. WRITE PORT NUMBER DOWN IN NOTEBOOK!!!
- NOW CONNECT DIGIRIG TO YOUR RADIO BASED ON ITS REQUIRED CONFIGURATION.
FOR FT-950 GREEN TO CAT CONTROL and 9 PIN TO PSK SOCKET. - CONNECT CABLES TO DIGIRIG
- TURN ON RADIO
- ACTIVATE DIGITAL PROGRAM YOU ARE GOING TO USE.
NOW THE REST OF THIS IS THE SET UP I USED FOR JT-X - OPEN SETTINGS
- OPEN GENERAL TAB AND PLUG YOUR INFORMATION IN AND SELECT THE FEATURES YOU WANT TO USE.
- OPEN RADIO TAB - SELECT “NONE” FOR RADIO. now this is very IMPORTANT, ONLY THE PTT BOX WILL BE LIGHT UP, PUT THE COM PORT NUMBER YOU WROTE DOWN IN THE BOX.
- OPEN THE SOUND CARD TAB, SELECT THE PNP SETTINGS FOR BOTH SOUNS AND MIC.
- SET YOUR LOGGING CHOICES AS YOU WISH.
- GO BACK TO RADIO TAB, CAT CONTROL SHOULD HAVE ALREADY HAPPENED, PRESS PTT, RADIO SHOULD KET.
IF ALL IS WORKING CLOSE SETTINGS AND ENJOY JT-X
