Total Noob to FLDigi but since the 718 apparently excels at RTTY, I thought I’d give it a go and try it. But FLDigi seems excessively hard to configure. What am I missing?
What functionality do you have difficulty configuring?
- audio from radio to computer
- audio from computer to radio
- PTT
- serial CAT control
Yes… All of it. But lets start with Serial CAT Control because that might help with everything else.
I should have mentioned this is my Digirig Mobile that stays plugged into my base radio and it works great with WSPR and JS8-Call. Sorry I left that out.
I’ll give the vid a watch and see if it helps. Thanks!
i haven’t used fldigi much.
i’m an ‘old free version’ ham radio deluxe kinda guy.
in fldigi though, try:
configure, soundcard
audio ‘tab’, devices ‘tab’
that should get you audio in/out (the device ‘names’ should be just like you set in js8call)
then;
rig ‘tab’, hamlib ‘tab’ (choosing hamlib gets you rig control/ptt without running flrig)
choose ic-718 (i know, obvious)
do NOT choose/check RTS +12v (this option would power up a homebrew interface, NOT the digirig)
now, on the hardware ptt tab, use serial port and RTS (not rts +v)
as in your other programs, you need to double check serial/comport ‘numbers’ and baud rates to match the radio itself (ci-v rate) etc.
