Problem: I cannot connect my FT-891 to Digirig and ACLog.
WSJT-X connects fine, and I am able to change frequencies using the slider bar in WSJT-S and by manually changing it on the radio.
When I try to load ACLog and setup the rig controls I am not able to find the proper settings. WSJT-X is using COM6 and CAT is using COM4. In the Setttings I am told that I cannot use COM6.
If I unplug the Digirig I am able to get the ACLog settings where the rig will change frequencies. If I plug the Digirig back in, so I can have all working together I receive the COM6 error.
What am I missing? Any helpful hints are welcomed!
I’m still not able to SAVE the rig settings in ACLog. I receive a message that Polling still in process.
Also, I plugged the Digirig back in, and it will not recognize the port. Digirig worked perfectly with WSJT-X after I rebooted the computer.
AC Log settings:
Rig Name = Yaesu 891
Read Frequency Command = FA;
Read Mode Command = MD0;
Convert To Hex = False
Com Port Name = COM6
Baud Rate = 9600
Parity = None
Stop Bits = 2
Data Bits = 8
Power Option = RTS
Numeric Frequency = 21.074
String Frequency = 21.07400
Mode = DIG
Polling Rig = True
Polling Rate = 2000
Return Mode = True
Return Frequency = True
Mode From Frequency = False
Version = Rig Interface Setup 2.8 (Ctrl R)
Buffer = MD0C;
vy 73 de David AE4LH
