Windows 11, HRD, icom 703 (original), digirig mobile CIV, 706 cables,
I am having zero success in getting the installation to work. All I want to use the 703 for is digital modes.
(1) Windows does not recognize the digirig,
(2) Have downloaded CP210 files.
(3) No com ports are created, and no driver info in sound parms of device manager.
(4) HRD cannot connect without ports
(5) Guessing at the right connection point for the cables from digirig to 703 (except the din 13)
I know this is a user issue, but I am computer dumb.
Did I get the right configuration for the 703?
How do I get the ports actually installed?
If I connect my 7100 direct to USB port, I get com ports 3 and four HRD is happy.
I appreciate any assistance
Regards Mike
Digirig’s devices have to be detected by the computer before any other steps makes sense.
In your case the issue is likely due to the use of charge only cable. Please try sourcing a data capable USB cable.
Denis,
New usb cable got the Digirig and com port 6 was created.
now to get HRD to connect. HRD will search com port 6 but have not been able to actually connect to the 703.
So, I am looking for the right connection from the radio to the digirig.
Connected DIN 13 to serial on the digirig
Connected audio to the speaker on the digirig to the speaker output on the radio.
HRD cannot connect yet.
I appreciate the help, Thank you.
Mike K3MMB
  • 13 pin connector plugs into a matching accessory port on the back of the radio and straight black TRRS jack on the other side plugs into Digirig’s black socket labeled “audio”.
  • Angled TRS connector plugs into radio’s CI-V remote socket and the straight green TRRS jack on the other side plugs into Digirig’s green socket labeled “serial”.
Still no joy.
Looking thru the setup on the computer, under sound I do not see Silcon Labs listed as an audio source. I have “USB AUDIO SOURCE” and 'USB DIGITAL AUDIO".
Looks like (maybe) my driver install only half worked.
(also notice that I broke my FIRETV audio, but that is another issue all together)
Once again, I truly appreciate the help.
73 Mike/K3MMB
"It's the Soldier who salutes the flag, who serves beneath the flag, and whose coffin is draped by the flag."
silicon labs would be the serial port (digirig cat/ci-v control)
usb audio would be the digirig ‘soundcard’
(it’s a generic ‘thing’ so whichever sound device appears/disappears when plugging and unplugging, is the one you want to select in HRD)
the 11th hour, the 11th day, the 11th month - Thank You for your Service.
Now down to business:
I uninstalled the streaming (OBSPROJECT) software and now the HRD and Finds the radio. It is working digital perfectly.
Thank you all for your help.
73 Mike K3MMB
