I connected the Digirig to the computer before turning it on. During the boot, the system said that the system needed to be rebooted for the drivers to be loaded. I rebooted. There was one device listed as USB Audio Device with a Microsoft driver loaded.
The CP2102N USB to UART Bridge Controller still had an error. Is this driver used for PTT? One attempt to load a CP2102N driver was not recognized.
I’m planning to first do APRS receive first, when work on transmitting.
I will see if I can use USB for receive with Direwolf to a log file.
The CP210x USB to UART Bridge VCP Drivers install as a COM3 port.
There was not change on the single USB Audio Device.
Uninstalling the Microsoft driver and installing the CP210x USB to UART Bridge VCP Drivers did not result in an installed sound card driver. Eventually Microsoft installed a 2016 USB Audio Device driver.
