I am running WSJT-X on Linux Mint with a Xiegu G90 and Digirig Mobile. Receive works fine, but Test CAT turns the transmit on and it wont shut off. I’ve tried different radio models in the settings among other settings changes, but nothing is helping.
Here are my Radio settings in WSJT-X:
Rig: Xiegu G90, Baud Rate = 19200, Data Bits = 8, Stop Bits = 2, Handshake = None, Force Control Lines = both off, PTT Method = CAT, Mode = Data/Pkt, Split Operation = Fake It.
Could someone please post their working settings, so I can eliminate that part of troubleshooting? Thanks in advance!
I changed the rig to flrig, same problem
I figured it out… I mistakenly had VOX turned on in the G90 and had CAT selected on WSJT-X.
