Xiegu G90/ WSJTx- suddenly getting HAMLIB error
I have had no problems with the Xiegu and WSJTx since I started using digirig, a few months ago. Today, I am getting Rig Control error from HAMLIB, when I check PTT “command rejected by the rig”. But CTL connects fine. I have checked cables, coax connections, Sound card settings, and all looks good. Did I blow Digirig somehow? Did I fry my USB? an suggestions? I don’t have another radio I can try it on.
what make/model is the radio?
have you always used PTT via CAT or were you using PTT via RTS in the past
Xiegu G90
Yes I have since getting the Digirig, always had CAT and PTT working ( no DTS or DTR. I have used the Fake it option. Have over 480 confirmed contacts since April
Thanks for the question
qsl
can you try selecting another radio definition in wsjt-x?
g106 or the x5105
maybe try the icom 7xxx series
(that’s what we used before xiegu definitions were written since xiegu uses the icom ci-v command structure)
i have the g90 and x5105 as well.
i ended up changing the radio definition on one of the programs i was using.
this was soon after a firmware update of the g90
the ptt specific rejection isn’t something i’ve seen before though.
the only thing that comes to mind is if the radio, unmodified, is rejecting an out of band TX.
like a split setup pushing the tx freq outside the ham bands etc.
probably not your situation but the ptt rejection has me stumped.
I can try that, thx
How can I check and take it out of Split?
Thanks for both suggestions
I did check and found that the “handle F1” was SPLT, I changed to PRE/ATT. Also change WSJTX radio choice to Icom 710 and it now is working. I actually received one contact from another station- but right now Kp=6 so pretty poor conditions.
But it is working normally
Thank you!
sweet!
glad you got it back up and running.
poor band conditions just add to the challenge right?
:wink:
That’s for sure, maybe see you on the air
N4RJB.
