Im looking to buy or make a cable between the digirig and a xtl5000 had anyone made one or know where i can get one
Dylan n3pym
From the pictures of the rig it looks like there are lots of connectivity options.
At this time there are no store cables matching any of the connectors so it will have to be a homebrew. Please share the pinout of the connector you want to interface and I’ll give the wiring info. As minimum we’ll need ground, audio in (mic or line-in), audio out (spk or line-out) and PTT. For extra credit we can connect optional serial lines (TX and RX).
Here’s a helpful image (found here), though pin number don’t appear to match with the table in above post:
Based on that, Digirig’s audio cable will look like this:
DB25 pin 7 (GND) → 3.5mm TRRS sleeve (GND)
DB25 pin 14 (PTT) → 3.5mm TRRS ring 2 (RIG_PTT)
DB25 pin 24 (Radio RX) → 3.5mm TRRS tip (RIG_AFOUT)
DB25 pin 25 (Radio TX) → 3.5mm TRRS ring 1 (RIG_AFIN)
Hello everyone!! I’m looking for how to assemble a cable interface to use RoIP on a Motorola XTL 5000! Does anyone have the CA or interface and connections diagram? I haven’t found anything on the internet about a home solution! Thanks
pinout diagram above ^^
copied from web search:
J600-1 AUX_PTT
J600-2 RS232_RX= UARTA_TX= DCE_TX
J600-3 RS232_TX= UARTA_RX= DCE_RX
J600-4 RS232_RTS= UARTA_RTS= DCE_CTS
J600-5 BUS(+) (SB9600)
J600-6 RX_AUDIO
J600-7 AUX_RX
J600-8 AUX_TX
J600-9 RX_AUDIO
J600-10 GND
J600-11 GND
J600-12 DAC_OUT
J600-13 EMERGENCY
J600-14 BUS(-) (SB9600)
J600-15 VIP_OUT_1
J600-16 IGN
J600-17 RS232_CTS=UARTA_CTS=DCE_RTS
J600-18 GND (legacy)
J600-19 RESET (SB9600)
J600-20 A+
J600-21 GND (SHIELD)
J600-22 SW_B+
J600-23 BUSY (SB9600)
J600-24 SPEAKER(-)
J600-25 SPEAKER(+)
