Yaesu FT-70D + digirig + flrig
Hi everyone, just setting up flrig and I can’t get the PTT on my FT-70D handheld to activate, the only way to get it to transmit the data stream is by manually pressing the PTT on the radio, it may be something insignificant, but it’s my first test.
That sounds frustrating. Have you installed the serial port driver for your OS? Can you see the serial port in your OS list of devices? If so, then maybe the flrig configuration is the issue. The Digirig triggers PTT via the RTS signal on the serial port.
Luis,
Adding to Constrained’s suggestion, please check out this video for configuration examples and troubleshooting.
