Yaesu FT-897 - My Settings
Here are all my settings for the FT-897, which is connected to an Evolve III Maestro Windows laptop with a digirig and cables. These are as close to universal settings as I have found for this transceiver. I don’t use any software attenuation with this setup. There may be other ways to set this up that work better, but this is what’s working for me. It may be a good starting point if you’re struggling to get this radio running.
For my settings on Winlink, click here: Winlink FT-897 Digirig; my settings - Digirig Forum
Windows sound settings
Flrig 2.0.02
JS8Call
FLDIGI
WSJTX
VaraAC
Transceiver settings
RF Power Set (menu 75) of 50 watts and over creates enough RFI to cause connection issues with my laptop. Your mileage may vary. If you encounter strange, inconsistent connection issues, drop power, space equipment apart, ground equipment, and put ferrites on both ends of everything. 40 watts max does well with my setup.
Dig Gain (menu 37) set to 8 or 10. This puts the ALC meter just above the “C” on the transceiver’s screen, and ensures full power output (measured with a meter plugged in under the transceiver front end). Some modes seem to need more or less Dig Gain. If the Dig Gain is much lower, the transceiver will have no output power.
CAT Rate of 4800 is required by my AT-897 tuner.
AGC on and set to fast. The AGC on this transceiver is outstanding.
Thanks for sharing. This is great info.
My only note is that I would move “default communication device” from Digirig’s audio components. These are used for voice over IP calls so if you answer a Skype call the other side might get a chorus of FT8 from your radio :slight_smile:
Oh, I didnt realize that! Thank you; I will change it.
Do you have any advice for how to do this? I am not finding the setting to remove the default communications device label from the digirig.
In Windows 11, I use mmsys.cpl to select another device as the default communications device:
Selecting another device will unselect the Digirig USB audio device.
@Drew_Rinella Also thanks for being one of the all-time great contributors to this forum, ever since I have been on here.
Thank you for the advice and the kind words.
I went through the process of working through install and setup of current versions of WSJT-X, JS8Call, and VARA just before Field Day. The mmsys.cpl tip is absolutely critical to getting things to work correctly.
I found that I had to set the Windows speaker output (the Digirig device) to 100% and enable AGC to get enough output for a reasonable signal strength in WSJT-X and JS8Call.
This seems counterintuitive to me and I was surprised at the boost in receive signal indicated in the software when operating.
I’m going to revisit my setup and check everything. I made some contacts using Winlink/VARA HF and FT8 for FD. I still have the nagging feeling that I don’t have my setup truly dialed in.
Thank you for taking the time to make this set of instructions for working with this legacy rig.
73 de AG7TX
