Yaesu FTA-250L VOX Issue with Digirig Lite
Hardware Setup
  • Yaesu FTA-250L aviation transceiver
  • Digirig Lite audio interface connected to Mac computer
  • USB isolator between computer and Digirig Lite
  • Standard 3.5mm TRRS male cable with Mobilinkd adapter (https://digirig.net/product/mobilinkd-adapter/) connecting Digirig to radio
  • No SCU-42 adapter being used
Radio Configuration
  • VOX: ON
  • VOX Level: MAX
  • VOX Delay: 3.0 SEC
  • MIC SELECT: EXTERNAL
  • Noise Cancel: OFF for testing
  • Operating mode: COMM (on aviation band)
Tests Performed
  1. PTT Test (Manual): When physically pressing the PTT button, transmission works correctly. Radio transmits audio from the Digirig, and another radio can receive it. This confirms basic audio path is working.
  2. Audio Frequency Sweeps: Created and tested Python script to generate various audio frequencies:
  • Sine waves from 100Hz to 3500Hz at different durations
  • Square waves (which typically trigger VOX better)
  • AM modulated tones
  • Various amplitude levels and gain settings
  • Special VOX trigger patterns with sharp attack characteristics
  1. Visual Confirmation: When playing audio tones through Digirig Lite:
  • The Digirig’s red PTT light illuminates (indicating it detects audio)
  • The Yaesu’s TX indicator light does NOT illuminate
  • Audio can be heard on radio speaker (with volume turned low)
The Problem
Despite the Digirig Lite’s PTT light coming on when audio is played (indicating detected audio), the Yaesu radio’s TX indicator never lights up and does not go into transmit mode with VOX operation. However, manual PTT works perfectly with the same audio setup.
This suggests a disconnect between the audio being sent to the radio and the radio’s VOX detection circuit. Either the signal isn’t reaching the VOX circuit correctly, or the VOX circuit is not recognizing the audio characteristics coming from the Digirig as valid for triggering.
Relevant Observations
  • VOX works fine with physical button press
  • Red TX light on radio does NOT activate during audio test tones
  • Red PTT light illuminates on Digirig during audio
  • Audio path is confirmed working (manual PTT test)
  • All VOX settings appear correctly configured
Has anyone successfully used the FTA-250L with Digirig Lite and Mobilinkd adapter for VOX operation?
Any insights would be greatly appreciated. I need this working for an automated weather reporting system.
It sounds like you use Digirig cable with Digirig interface. What is the intended role for the Mobilinkd adapter?
Thanks for taking the time to review. My eventual goal is to get this running on a rasppery-pi and I thought I needed it. Right now I am trying to get everything working on my macbook and then transfer the python script to that system.
I tried with and without the Mobilinkd adapter and did not have any success. Here is a short video of my setup in case that helps: Watch PTT_VOX_TEST | Streamable
I found only if I push in the cable it seems to trigger the PTT. Please let me know if there are any other tools I can try out to get it working. Thanks!
The cable/radio need to pass the PTT test with shorting of the pins on the other side of the connector as demonstrated in this video:
Once that is confirmed we can move on to dealing with PTT settings in Digirig.
If
Thanks! I installed wsjtx and tried doing the PTT test, but since its a Digirig lite my understanding is there is no COM port for the device. (reference: 878UVII+ not transmitting with DigiRig Lite - #4 by N4EJM)
I changed to VOX but the test PTT button is greyed out. Any recommendations? I selected the audio input/output in the other panel
in the preferences.
Thank you for additional information. The test I was suggesting is the one when you short sleeve to ring 2 contacts on Digirig’s end of the cable. If cable has the correct connections that should make radio key up.
The test in question doesn’t involve software, computer or even Digirig.
We found the problem. The socket on the Yaesu FTA-250 has a ridge on it which prevented the plug from fully seating. An adapter cable was purchased that had a different plug design with a brass ridge on the plug base allowing the plug to fully seat into the Yaesu socket. The cable came from Amazon, (Tan QY Male to Male Audio Cable). Everything works great now.
