Yaesu FTDX-1200 Digirig Issues
Hi Everyone,
So I bought the cables I need for my Yaesu FTDX-1200 and have been trying for months to get this thing to work. I then put it off for a few months as life got pretty busy and I’m back at it trying to get it to work but no matter I do nothing is going to the radio. I’ve tried to get this to work on WSJT-X and CAT control just fails each time. I have the pads in the Digirig soldered for RS232 as this radio uses RS232 for CAT control. So finally I decided to do a loopback test and followed the instructions provided on the troubleshooting page here on the Digirig website. Now my issue is all I have connected to the digirig is the USB-C cable from Digirig to the Digirig itself and I’m getting character output in PuTTY without even connecting the TRRS to DB9 cable. Am I looking at a defective Digirig board? Or is there something that I’m missing here? Any feedback to help solve this issue would be awesome.
Ok so I’ve figured out why the digirig was outputting without anything connected to it, it was because I still had a bit of the logic level pads still connected so I’ve gone over it again with an xacto knife and ensured this time nothing remained on those connections and I resoldered everything to be on RS232 connections however now when i do the loopback nothing is coming back. I may have a dead cable.
Lou,
When you are doing loopback test, make sure you connect pins 2 & 3 on the DB9 side of the cable.
DM if you want me to re-test your Digirig and make sure that the serial port survived the solder jumpers modifications.
I can’t really speak to the hardware issue as I am using the RS232 configured Digirig and Digirig cables, but I can tell you I have successfully configured Winlink to work with my FTdx-1200 using the Digirig with CAT control. Once the Digirig and cables are correct there are specific configuration changes that need to be set in both Winlink and in the FTdx-1200 menu without which you are doomed to a life of disappointment. If you would like me to post the settings let me know otherwise I hope you have sorted it out.
I’d hate to necrothread from almost a year ago, but what menu settings were you using to get the FTdx 1200 working on digirig? I am trying to help my friend who uses the exact same radio and we can’t get the radio to output to the computer.
Yaesu FTdx-1200 Digirig Settings
Vara HF settings using the Yaesu RS-232 Digirig
Radio Setup
Select Radio Model = Yaesu FT-450
USB Digital = checked
Radio Control Port
Serial port = COM13 Baud = 38400 RTS & DTR = unchecked
PTT Port
Serial port to use = Y450 Baud = 9600
There are a bunch of settings in the radio that need to be adjusted in order for Winlink to work with the 1200. I found a blog on the internet that listed the settings for another Yaesu radio and those worked for the 1200. I saved a copy of those on the computer as a .pdf.
Manually change the radio out of USB DATA mode using the mode button if you want to go back to voice SSB
The com port may be differant for your computer so use whatever the Digirig port number is assigned by your device manager. I can try to find the radio settings if you need me to.
Corey
I would really appreciate it. Every few months I’ve given it a try to no avail.
What about the blog post you found? Having trouble with VaraHF on the FTDX-1200 with Digirig. Thanks in advance!
@mikemeek,
please describe the nature of the problem you experience with your VaraHF setup and I’ll be happy to advice.
The problem was that taking the signal from the RTTY was offsetting the output of the Yaesu FTDX1200 (received signal appeared at the very top of the VARA waterfall.) I changed setting 103 SSB MIC SEL from FRONT to DATA, then used SSB mode rather than SSB data. It all works now.
