Can you program the FT-60 using a digirig with chirp?
Yes, Digirig’s serial port can be used for programming, but a programming cable is needed to connect to the radio. It will have different pinout from the audio cable available in store, should be fairly easy to homebrew.
Thank you I had a new ham in my club looking for a cable and I recommend the digirig because of its multi use. But wasn’t sure of programming part. I knew the baofeng has two cables but wasn’t sure about the ft -60.
