I have an old Icom IC-730. Has anyone made a cable from the GX16-8F microphone connection to Digirig? Not sure if the pin config for the ALinco is the same? Have a service manual but it does not show the pin schematic. I only require PTT, mic and audio out, not serial. Have only a digirig lite so a single 3,5mm jack for ptt, mic, spkr is all that is required.
Using a standard Baofeng cables kit for Digirig Mobile on my Quansheng UBK-5 with Winlink via VaraFM and works well on VHF/UHF. Now trying to get it to work on HF via my IC-730.
Moved topic above to
GE,
I came here after looking for a cable for a TS-590SG.
- While in the store, I tried a search on 590SG. No joy. Finally got BACK here by doing a Google search.
- Found the images initially confusing, because the connector on the right is rotated just enough to have given me the impression that it was labeled wrong. Could benefit from having the same orientation as the connector on the left.
- And finally! the comment about audio and the TRS connector is a key piece of info missing from the store page. I was wondering which style to buy, and had no reference in mind that would make either the correct purchase. I’ll check the 590SG manual to see if audio is on the connector.
73 Rich NE1EE
