Cable for TYT TH-8600
There is a data port in the back but according to the manual it is only used for programming. With that we’ll be going the typical route for mobile rigs with Mic/PTT connection in front and headphones connection in the back.
The aviation type mic connector looks like GX12-6 or GX16-6.
The headphones connection use BTL design so we can’t connect ground on TRS connector for the audio output. See more details on this situation in another post.
The cable pinout should be:
GX pin #1 (MIC) → 3.5mm TRRS ring 1 (RIG_AFIN)
GX pin #2 (GND) → 3.5mm TRRS sleeve (GND)
GX pin #4 (PTT) → 3.5mm TRRS ring 2 (PTT)
3.5mm TRS tip (headphone) → 3.5mm TRRS tip (RIG_AFOUT)
Does one of your cables work for the TYT TH8600?
Unfortunately, none of the off-the-shelve cables available at this time would fit this model.
The microphone connector for this radio is the GX12-6.
Did you get a digirig working on your TH-8600? Thinking about making a cable. To add some more utility to this radio that I have in a field box for quick deployment. I would use it more for impromptu winlink or APRS.
If you built it and no longer have a need for it, I’d buy it off you if it’s collecting dust.
Sorry just logged back into the forum.. I have not yet purchased/acquired all of the parts to put this together. I will post back here once I do an can confirm it works.
I made the cable per the specs in this thread and it works! The rear TRS jack on this radio kind of pops any TRS male plug out a bit but it makes contact with the tip enough to work.
Glad to see it working for you. I put mine together and found the same issue with the audio on the back. otherwise it works great.
