Cable for Anytone AT-778UV
Like in case of many mobile transceivers we’ll need to gather required signals from multiple connectors:
The audio must come out of the headphone jack, though there is a bit of a gacha there.
The amp uses a bridge-tied load (BTL) design while Digirig expects unbalanced input against the ground.
We can either:
  1. use an audio transformer from tip and sleeve on transceiver side to primary winding and from secondary winding to ground and RIG_AFOUT on Digirig side or
  2. just connect tip to RIG_AFOUT and leave sleeve unconnected on the transceiver side. This effectively halves the amplitude, but Digirig has enough sensitivity that this is not going to be an issue
So the final cable layout is like this:
RJ45 pin 1 (GND) → RJ45 pin 4 (MIC GND) - this may be not required and needs testing
RJ45 pin 1 (GND) → TRRS sleeve (GND)
RJ45 pin 2 (PTT) → TRRS ring 2 (PTT)
RJ45 pin 3 (MIC) → TRRS ring 1 (RIG_AFIN)
TRS tip (EXT SP1) → TRRS tip (RING_AFOUT)
TRS ring (EXT SP1) → NC
TRS sleeve (EXT SP2) → NC
Users-Manual-3731629.pdf (1.5 MB)
Are you using 2 TRRS plug or 1 and doubling up wire? I am hoping to adapt this to my BTECH UV-50X2.
Not sure if that’s your question, but you can use TRRS in place of TRS connector, just short unused ring to sleeve:
I folks, just had some success hope this helps AT-778UV Home Brew Cable or Box - Solved
Just got the marketing email for the new cable so this may be a bit late. On the “Up” pin /Black /5 on the connector, you can put an .1uf to 1.5uf capacitor in line to the mic/ audio in for the digrig, and set the radio audio out to “SpeakerMic”. When in this mode, audio out will go through this pin, but without the inline capacitor, it will just trigger the “up” button on what would be the hand mic. This will allow you to use a single cable from the RJ45 connector on front to the digirig for full PTT/audio interface without the need for the audio jack on the back.
Thank you for the information. Yes, that would make it a cleaner connection. Digirig has capacitors on both audio lines so there would be no need to add them in the cable. Will anybody be able to test the proof of concept for this cable variant?
I’ve actually been using this. Unfortunately I didn’t take any pictures during the build. But I just spliced an old Ethernet cable to a TRRS plug using your diagrams above along with the change on mine for audio out of the radio, and wired it to my digirig running in the standard configuration. It has been my go-to APRS / Direwolf interface.
It has been a while, so it would be nice for someone to confirm. My memory sometimes fails me.
I just got this cable and I cannot seem to get it to work with Chirp. I tried switching out the cable from the Audio to the Serial and still nothing. I tried both options on Chirp 778UV and 778UV VOX and NO LUCK.
Was this cable not designed to program the radio? Do they sell a separate cable? Most other cables come with one with a green tip for programming. This one only came with one cable that has an RJ45 and audio for the speaker.
This is the audio cable for use in digital modes, it’s not intended for programming. At this time there is no pre-made Digirig programming cable for available for AT-778.
Does the digirig lite also have the capacitors on the audio lines? It’s triggering the up button so maybe the lite version doesn’t work as well with the RT95. Maybe i just need to take audio from the speaker jack.
Yes, there are capacitors on the audio lines:
Looking at the connector pinout for AT-778 earlier in the discussion, the buttons are on the separate lines (UP is pin 5). Check the connection in the cable to make sure they match the cable schematic.
I installed a capacitor according to Modernham’s description, the cable is now working great with the RT95 and digirig lite! I appreciate the digirig forum and everyone sharing knowledge and solutions.
Kinda bringing this back from the dead, but I found that someone figured out that RXD and TXD both go to pin 8 on the Anytone, ground to ground for serial. So if someone took pin 8 from the Anytone connector along with pin 1, and put pin 8 > tip, pin 8 > ring, pin 1 > sleeve, would that work for the serial connection to the UART in the Digirig?
Here’s the site I found that shows how another ham made a serial cable for the 5888UV: https://www.avalonarc.org.uk/2019/05-12-how-to-make-a-programming-cable-for-the-anytone-778uv.html
So my thought is take pin 8 and send it to T and R, gnd to sleeve, and add a green serial 3.5 TRS?
That should work. The RX/TX connection is is not exactly safe if radio talks back to the interface. A better option would be switching Digirig’s configuration to CI-V which will be functionally equivalent but without risk of outputs colliding.
I just had the same problem with my AT-778UV while making a cable for the DIGIRIG Mobile. I saw your fix and put a 10uF capacitor inline with PIN5 of the mic connector. It appears that Anytone is using the line for the UP function of the speaker mic as well as riding audio on the DC for the speaker in the mic. That being said, I took a look at the schematics of the DIGIRIG Mobile and found that there is a RC network for the input to the CM108 chip. I believe that the 3.3V DC that is on the line along with the audio is creating a timing circuit that triggers the UP in the radio. Once, I put the capacitor in line and blocked the DC from the input of the DIGIRIG, the problem went away. Thanks again for the heads up and the fix.
