Digirig and Yaesu-FT5DR from scratch
Hi everyone, my apologies in advance for reviving this topic but I am essentially starting from scratch. My question is, can someone provide me guidance to setup my FT5DR, laoptop and Soundmodem for Winlink operation. I have the cable from DR and believe I am ready to go. I am familiar with Soundmodem and have used it successfully with a Signalink. The DR will be a nice upgrade. I want to learn how to use it.
Could someone point me to instructions to setup the FT5DR for Winlink? I looked around here but no luck. I’m sure it is here and I have overlooked. 73, John - NO0I
Maybe a Yaesu FT5DR user will respond.
In the meantime, if you follow the setup instructions for any HT, e.g. a Baofeng UV-5R, you will get 80-100% of the way to success. Unlike the Signalink, with the Digirig, you should choose to pull PTT rather than rely on VOX.
Let us know what you find.
If someone should need some help they can dm me and I can attempt to walk you through…Caution…this is very tedious and time consuming sometimes…your odds may vary…
Except for the PTT method, your setup with Digirig will be similar to that with Signalink.
Check out this post:
