Digirig for Anytone D878UVII Plus
Which Digirig would you use for the Anytone D878UVII Plus? And which cables?
These cables might be right:
Baofeng cables kit for Digirig Mobile – digirig
You need the logic levels configured digirig: Digirig Mobile – digirig
See this post for cables: Cable for Anytone AT-D578UV III Pro & Plus
You can make/buy the audio-only cable for RTS PTT, or at the bottom of the post there’s an audio/serial cable that you can make that will support CAT PTT. I’m working with Hamlib to get the Anytone added to the library, it’s been added to VARA FM, and SoundModem. There’s more info about compatible software here: Home · jrobertfisher/AT-D578UV-software-mic Wiki · GitHub
I have been wanting to use my 878 with Winlink. I asked the Bridgecom folks at Hamvention and they told me they were working with Denis on getting it to work but that it’s not ready yet.
Your AT-878 works with Baofeng audio/PTT cable. More info in these posts:
https://forum.digirig.net/tag/anytone-at-878uv
I successfully used the Baofeng cable with an Anytone 878 on Winlink. I found that I had to increase the TX delay to 600, but it does work just fine.
I made this video and hope it help!
Setting for Winlink on your Anytone 878 or 868, using VARA FM with a DIGIRIG interface.
IN VARA FM SETTING - YOU WILL NEED TO SELECT PTT METHOD BY RTS OF DIGIRIG’S COM PORT.
Step-by-step setup of Winlink on Anytone 878/868
Configuring VARA FM with DIGIRIG for efficient communication
Optimizing your setup for both Windows 10 and Windows 11
Hi Guys, I’m new to APRS and i’ll admit I’m a real dummy trying to figure all this out. I have two radios 578UV and an 878UVII plus. I have no problem with codeplugs. What I am trying to do is Track my location while i’m on a trip. So my question is WHAT DO I NEED TO BE ABLE TO DO THIS??? Hardware and which software? I tried for 3 days to use “PinPoint” just to find out the Anytone radio’s need something called TNC! So what do I need? Keep it simple please. I found this site while searching Amazon for TNC looks like the "digirig Mobile is an option. Will this work and what software and cables???
Mike,
Both of the radio models you mentioned support APRS internally so you should be able to report your location without adding any additional hardware. Here are some videos that came up when googling for “878UVII APRS” and “578UV APRS”:
Thank you very much for your advice, I did try and work more with the code plugs and I got both radios working and was able to track my progress on aprs.fi thank you very much.
Mike,
K0DMH
